Can I Remove Console?
Mellors500
My daughter put some pound coins on middle console and I thought they would drop through to the carpet so I could retrieve them.However I see this is fixed although some of the panels look as if they would prise off. I am hoping to retrieve the money without doing any damage - can anyone advise please ? :help:
Hi Mellros500 and welcome!
Did not quite understand where inside the console those coins are, but maybe this will be helpful?
But if those coins are at the bottom, try putting some thin flat thing there where you see red arrow
and lift:
If I remember correctly there (under that panel) is a light for the Es button, you will have to pull the wire/bulb
out to get that grey panel fully released.
Just open it a bit and have a look inside. You will figure out what to do... Good luck with the coin hunt! :thumbsup:
Best regards, Alex
