Abs Advice For St182
aclambert
Hi everyone
I've got a ST182 Celica (import) and I'm about to buy new wheel bearings. The part options specify ABS or non-ABS. Is there any way I can easily tell whether I have it or not?
If I hammer on the brakes the car will skid so I'm guessing not.
I haven't got an ABS light in my dashboard but not sure whether there should be or not.
Anyone know a bit about this model or a way I can tell for sure?
thanks for your help! :thumbsup:
just drive at about 30 - 50 km/h then slam your brakes on so they lock up if they lock up and dont pulse then you have no abs if it has like a strong pulseing braking then you have abs another way is if you have a look at your front/rear brakes there should be 2 cables 1 is your handbrake usally in the back and theres a small wire kind of cable that kinda plugs into your hub or sumthin
