Is Catacleaner Any Good
thesouthernguy
Im new to the forum and have a question about CataCleaner.
I bought it the other day to give the fuel injectors and cat a clean ready for the MOT.
But i havent gone and tried it yet!
I have a 1.8 VVTi Avensis 2002 and i really want to know whether this will make the well known oil useage problem worse.
Does anyone know anything about this product?
Or whether it will have side effects on the oil useage or my engine?
hi
try to find some drivers comments in enet.
i use to ultrasonically clean all four once a year and they serve well.
what is the problem with your injectors? are an idle revs not stable ?
in case you've oil consumption issue then nothing will be worse.
i would not use this chemical unless to be sure of its performance :)
cheers/Igor
