hi i have got an mr2 turbo j reg inport the problem is the turbo is not working and the car runnings good engine sounds fine it strats up fine but just drives like a non turbo car the boost gauge is pointing down and there is no boost at all and there is no blue smoke comimg from the exhaust thanks pete.
can you hear the turbo spool up?
there are a few things that can cause this issue. the first thing to check is that there a no split or insecure hoses. if all these are ok then its most likely turbo related, a stuck wastegate or it has been known for the ceramic tubine wheel in the exhaust side to disintegrate. if you can rmove the lambda sensor from the downpipe you can see in with the help of a torch. another common failing of the CT turbo is the shaft snapping although this is usualy followed by lots of smoke
no turbo spool up will check tomorrow for split hoses things like that thanks will let you no tomorrow thanks
Pull the elbow off the intake side of the turbo and have a look at the blades. Try and give them a spin too.
Will give you an idea if the turbo is locked solid.
thanks mate will check tomorrow and let you know thanks
hi mate i pulled the elbow off and it is spinning fine it looked clean inside as well have checked all the pipes there is no splits and every thing is on properly any more ideas thanks pete
hi mate checked al them things every thing seems ok also had the elbow off the turbo and the tubine is spinning fine and is pritty clean in side any other ideas could it be a fuse or any thing like that really suck with this one thanks pete
