Head Unit In 07
lammy29
got an 2007 yaris sr anyone changed their head unit? i got like an alpine system
i seen in usa, would it possible to do same thing?
Looks like the part you need is the fascia panel that is used in the models with the sat nav as in this picture: http://www.just-auto.com/articleimage.aspx?id=29983
Then to convert to single din the middle black part looks like the RAV4 fascia adapter you also had to use with the replacement genuine Toyota fascia in the older shaper 1999-2004 model. Autoleads part number: FP-11-03
http://cgi.ebay.co.uk/TOYOTA-RAV-4-FACIA-F...%3A1%7C294%3A50
do you know where i could get that fascia from? so tht eBay link is wat i need if i managed to get hold of the fascia?
You will only be able to get it from a Toyota dealer.
There is an aftermarket kit too if you dont want to get the two parts above: http://cgi.ebay.co.uk/TOYOTA-YARIS-Double-...%3A1%7C294%3A50
Not seen a picture of one fitted before so dont know if it will look as good.
Guide on how to remove factory stereo: http://techdoc.toyota-europe.com/legacy/To...%20000481-1.pdf
