1998 Camry Ignition Leads
Hi all, new here as I have just bought myself a Camry, first Toyata and so far I'm loving it!
Only problem at the moment is because the car seems to be quite rare in the UK parts are a nightmare :o
Does anyone know where would be the best to get a set of leads from though, Halfrauds want £110 and Toyota want even more so I'm trying to find a good quality set at a semi reasonable price. Bosch to a set for the 91-96 cammy with the same engine number but for some reason these apparently won't fit??
Any help would be appreciated!
Just incase anyone else has the same problem with leads in the future I found out in the end that the 97-01 Camry uses the same leads as the 2.0 Avensis. These were a lot easier to find and I eventually got a set of Bosch ones off of eBay for £50.
Fitted last week and they work fine!! Just have to find a new front bumper now seeing as my missus decided to use a taxi to stop instead of the brakes!! :angry:
  • 4 months later...
thata at a pretty good and reasonabler amount. just go for it
