Speedo Not Working
mick51
HI MY SPEEDO HAS STOPPED WORKING BUT IF I GO ON THE M62 AND PUT MY FOOT DOWN THE NEEDLE WILL SHOOT ROUND TO 140MPH THEN BOUNCE BACK TO O ANY SUGGESTIONS ;)
Speedos are electrical now not on a cable drive, so it sounds as if yours has a short somewhere on circuit board and yours occasionally clicks in and out when you go over a something to trigger a brief connection
Easy to change though and plenty for Gen 6 always popping up on e bay.
Not sure what gen yours is, but I would suggest a replacement is needed and easiest option
You could trace connections on printed curcuit if you were so minded and find fault ? maybe?
Hope this helps
