Need Help 3sge Beams Proyect
Well mates I'm new here, first of all I'm planing a engine swap for my Trueno AE92 and in first place I got in mind a 3SGE beams red top and I need that somebody here share some light. First I need to Know if the engine and tranny fits in the AE92 engine and tranny mounts, 2nd If it does, what would be the best modifications (con.rods, pistons, camshafts, air intake, valves, etc) if you can include the brands I'll be glad. I'll be thankfull if I can get some hints and info about it.
Yeap, I forgot if I can use con rods, pistons, camshafts, valves and some other parts from any other 3S engines (if is possible). Thanks
The Beams engine is rare in the UK, imports only.
I'd suggest you'd be better off looking at the Celica that had the beams Engine in, as that was front mounted, so would probably be a better match with the ancilleries etc.
Tuning is minimal, again as there are only a few cars out there with this engine. I'd have thought the std airbox/exhaust would be the only things available.
I'd look towards the Honda K20 engine, more power, and more mods out there. Also a wider user base as the engine is pretty much in everything now days.
