Buying Gen7 (2000 - 2002) Worried About Engine Oil Issue
ardz
Hi guys,
I'm buying a gen 7 only able to spend about 3500 so I'm limited to 2000 - 2002 reg ones. I'm extremely worried about the excessive oil consumption issue - the ones ive looked at have been from dealers and everything looks ok when I've looked at the engine/oil/dipstick. I am worried however that if I purchase one I'll have this issue later on to the point where im actually considering not buying it (which is a shame because it really is the most fun car I have ever driven :( ).
Did this problem affect all pre 03 models or was is just a 'bad batch'?
Thoughts or advice when purchasing much appreciated.
Thanks.
Hi guys,
Thanks.
anyone? i thought this was a celica forum! ;)
This problem only seems to affect the 140, so you could buy a 190 which only requires changing the Lift/Flange Bolts to the upgraded type. In your position however, I'd save a little more and buy a face lift 140. Apart from giving you peace of mind as regards the Engine, you'll gain larger front Brakes and a nicer Interior/rear Lights. You will probably have to do without the Premium Pack with your budget, but it's still a brilliant Car even without the Leather/Sunroof/Climate.
It doesn't seem to affect all pre face lift 140's, but as the problem is caused by a design fault as regards Oil ways getting blocked by carbon deposits, it could. By the Autumn you'll be able to pick up a face lift for £4K anyway :)
Dam sooooo annoying the problem is we need a new car ASAP and I really had my heart set on a celica!
hi guys,
referring to this thread here if i buy a 2000 x reg celica which has a FULL service history (does it have to be done by toyota?) and it then develops the oil burning/knocking issue will they repair the engine as part of this 'secret warranty extension' thing ive read about on the forum?
hi guys,
Hi
I think the warranty is for up to 7 years old,x reg is too old.
