Heater Problems
Pete Clarke
Hi everyone I know this is an old problem but here goes
Symptoms: Heater will only blow luke warm.
seems to be alot of pressure in the system causing it to blow water from the header tank.
Heater matrix is good as I have flushed the system through from the rad to get all the s**t out
Radiator was replaced prior to purchase.
checked thermostat and it seems to be opening ok.
have removed it to see if there is a drop in the pressure.
heater pipes are quite warm but heater still cold.
no oil in water or water in oil so head ok.
any ideas???????
any ideas???????
Head gasket has gone, it's pressurising the system and stopping water circulating properly.
any ideas???????
my 185 doing just the same the head gasket was changed back in nov last year just before i got it
Took the thermostat out to see if it would still push the water out.
car idles a bit faster but no water problems, although it never gets up to temperature.
replacing thermostat today.
watch this space.
p.s
anyone got any seats for a 91 celica?
or centre caps for the original wheels
Presumed you have checked the water pump is working by holding inlet and outlet pipes one should be cold the other hot. If they are the same, water pump is dead. If the outlet is just aired, water pump is probably "dying"
i had the same prob on my mk2 golf, turned out to be heater matrix blocked even though when you put a hose pipe on it water did flow though
changed the thermostat and put some decent antifreeze in and all seems ok
reduced pressure and not losing water.
fingers crossed :D
