Flash Codes
sillycarsally
i had a code 21 which was for the oxygen sensor i now chaged it and its gone. but in its place i got a constant flashing. and car still wont run. what does it mean. help!!!! i mean it just wont fire up. the codes all gone and just wont start. oh yes and i have the celica 2litre gt import model. nothing but trouble finding parts
steady flashing means no error codes are present , try taking off the earth from the Battery , press the brake pedal twice . refit earth strap .
as for parts buy for a uk st202 , all/mainly all/ the parts are the same as the jap model.
sweet man cheerss will try that out. just flashing is good news then not like killed my ecu lol. any reason why im not getting a spark tho. i changed plugs and distributor cap and rotary arm just dont spark tho. i think i might have possibly flooded my plugs from cranking and pumping the fuel threw.
If it has flooded just disconnect your injectors, take out sparks, and crank over engine this will vent the bores. Then a bit of WD40 down the bores to dry up the rest, spark plugs in oven to dry up any fuel thats in the porcelain and warn them up, back into the engine, plug in injectors, and crank it over again.
Also... I cant create a new topic. Can someone tell me why.. or just create me a topic titled "Engine misfire, now rarely starts.." and I can post my thread in there. Cheers.
