Auris Tr Radio Reception
Dave 3
I have a new Auris TR and I find the radio reception is a bit hit and miss, especially on BBC radio 4 and 2. Has anyone else had similar problems? Can you install an alternative radio? Any comments would be appreciated.
Cheers
I have the same car and no problems with reception, ensure the AF function is enabled. It follows those National radio stations and changes to the best signal automagically
Kingo :thumbsup:
Cheers
Kingo :thumbsup:
Ok, thanks Kingo I'll try the AF set up.
Dave 3
  • 1 year later...
Er same thing for me, AF does not help, turning of TA seems to help a lttle but it is still pittiful compared to my other car.
The effect is silmilar to a broken suppressor in the old days, like a build up of static, clear for a while then it builds up.
Also radio 4, the local stations are OK.
Chris
Kingo :thumbsup:
Dave 3
I'm the opposite from you guys, the reception in my Auris is the best I've had in any of my cars.
  • 4 weeks later...
I pinned down how to replicate the problem, mine is an 'auto', whenever you get it to change gear the electric clutch operates and causes interference.
I took the car to the local dealer and demonstrated the issue, they admitted there is a problem and revealed that there is a kit to fix it [whoever said Toyota had learned to admit problems?], but details are limited so far. The kit is just some ferrite beads so it should not be expensive, but no doubt hundred to fit.
Chris
