Misfire - Hesitant Accelerating On - St185 Advice
mad1969
i'm having problems with my 185 runs fine for about 15/20 mins holds boost pulls well though the gears then all of a sudden the boost drops of 2-3 psi and the cars holding back
iv check all the boost pipes all seem ok apart from the main air filter hose that fits onto the turbo its got a split iv tape it up and check it when the car is running and carn't see feel and air escaping
seal the air filter hose with some gaffer tape and check your plugs and leads, misfire on acceleration when warm is usually these failing
