To Buy Or Not
igormus
Hi GUYs
I need your advice whether to buy or not the subject vacuum cleaner.
It looks good initially, but i am still in doubts with its performance -- whether it would be enough to clean saloon?
All commentst are appreciated.
Cheers/Igor
Hi Igor
I'm not a fan of handheld/rechargeable vacuum cleaners. To my experience you don't save any time or effort instead of using a normal mains powered one - because of the smaller one's inferior suction power you end up vacuuming the same area over and over again. Buy an extension lead if you can't get your mains powered vacuum to the car. Having said that, I don't have much experience in using them (think I've only used 2 so far) so you might be better off getting a reply from someone who actually owns one.
A quick search only revealed this review:
http://www.amazon.co.uk/Electrolux-ZB412C-...d/dp/B000UL8R1S
Hi Igor
ok thanks a lot for yours prompt.
waiting for anothers.
cheers/Igor
Hi Igor,
Ive had 2 hand held Vacumn cleaners for the car as its used for as a part time taxi on the weekends, but neither of them pick much dirt up at all. Personally I think they are a waste of money, but thats just my opinion.
Best sticking to a home vacumn cleaner to be honest
Hi Igor,
hi Jamy
i do not believe the famous brands do not offer good solution to kill dust :)
as far as i see the common opinion looks the same -- ok it is better to visit a bar instead :D
cheers/Guys
hiya
having owned a couple in the past, i can say as well that i do not like them for the car. they do not have the power to suck up properly, like a mains powered one. save the cash, and buy an extension lead instead!!
cheers
mike
hiya
cheers
mike
:thumbsup:
thanks guys <=> i am not along , in fact
