D4d Breakdown !
rob virgo
after a run yesterday stopped the car at a shop and it wouldnt restart.fired once or twice on the starter but sounded like an engine running on (like a tractor with out exuast). throttle having no effect on running at this point.i shut it off as it sounded so bad.
had to call tow away and he got it going by pumping up fuel filter plunger(one/two strokes to hard) and a squirt of easystart into intake.
he suggested the fuel pressure but didnt know if one or two fuel pumps.is there a lift pump and high press pump in 2004 avensis d4d engine.
any other ideas on what this could be,seems down on power as well so suggestions please.
if its the fuel pump i can fix myself if i know where it is.
rob v
rob v
hi ROB
please reply the below listed, asf:
- the last works list during service;
- whether you had diesel in the tank?
- whether or not the fine fuel filter was changed before?
- whether you have taken over on fuel injectors (what is their condition)?
- check with two solenoid valves mounted on the HP fuel injection pump (el circuit -- alive or not -- in case of positive - the valve must to click !);
- unscrew one of the injection pipes from injector or even fuel pipe from fuel pressure retainer and be assured the HP pump delivers diesel in comon rail.
- whether someone has been adjusting injection timing before?
Please check and revert shortly
Cheers/Igor
rob v
hi ROB
Cheers/Igor
besides
there is a booster pump (manually driven)mounted on the fine fuel filter upper case. try to pump it, but when ignition is ON (without starting), otherwise both solenoind valves do not allow diesel to be sucted into the injection pump (!!!). try it first;
secondly when pumped - have an air escaping bolt released to check whether an air is available in the filter (it is bad agent for filter). Besides -- when the fule filter element was last changed???? May be the problem is there. In order to eliminate all chain links -- you must be sure that you act step by spep.
cheers/Igor
rob v
hi ROB
Cheers/Igor
besides
whether your engine is chain or cam belt driven (i mean for injection timing)
cheers/Igor
besides
cheers/Igor
rob v
hi ROB
oil and oil filter
full tank
about 20 k ago
dont understand,toyota ran dianostic on eng inc injectors,no fault found
will do,is this with ign on or off,is it very high pressure ex pump.
will do,
no one has done any work here
i have changed the fuel filter today as a first step.will let you know if that improves ,should notice on drive as car seems down on power before.
cheers for your advise.
rob v
Cheers/Igor
hi ROB
oil and oil filter --------------------------OK
full tank ---------------------------------OK
about 20 k ago ------------------------ IT IS LONG TERM OF SERVICE !!!!
dont understand,toyota ran dianostic on eng inc injectors,no fault found ----- NORMALLY THEY MUST TOO SHOW THEIR PERFORMANCE TO YOU BEFORE INSTALLATION !!!!!
will do,is this with ign on or off,is it very high pressure ex pump. --- DO NOT DISMANTLE -- JUST HAVE MULTITESTER AND CHECK WITH RESISTANCE OF EACH COIL.
will do, ------ OK put rags around not to spoil diesel on other parts
no one has done any work here ---------------------- OK
cheers for your advise. ------- OK
ROB --- try to test drive tomorrow or even today.
I feel that the problem was with filter due to age
good luck + come back with any reply
Igor
hi ROB
Igor
yes ROB
onething else -- do not forget to remove an air from filter !!!! otherwise you'll have huge vibration on idle revs.
Igor
cheers lads , great help on this forum. :thumbsup::thumbsup::thumbsup::thumbsup:
where is the scv and how do i test
how often should fuel filter be changed
ran the car last night and it responds much better now.will see if problem reappears over the next few days.hopfully sorted.
145k on eng , should i check turbo boost pressure,whats std psi.i know actuators on previous turbo cars i owned got weak and reduced boost.has anyone checked this on a high millage car.might be another few bhp lost there
rob v
car failed to start again today.
i pumped the fuel filter booster and it started then
i am thinking of ordering a new lift/low pressure pump today.
but i am wondering if its air in the system tho,i dont see a bleed valve on top of the filter housing.
i tightened the filter with a spanner where i have been told it should be hand tight.i dont have leaks but could i be drawing in air.
rob v
rob v
hello
be noted that the filter with booster are located higher than fuel injection pump, so there most likely the sealant of booster plunger is worn down resulting an air is sucted on rod back stroke. Pay attention of this sealing first.
Cheers/Igor
rob v
hello
Cheers/Igor
does this mean replacment of the unit that the filter attachs to or just a new filter.
pics below
rob v
hello
Cheers/Igor
pics below
basing on the photoes -- no one can reply you definitely --- i deem this filter (only lid assembly) has been in use for a long time and the following faults must be considered:
- O-rings worn down or installed incorrectly;
- booster diafragme could be worn down with some micro cracks
you can not evaluate it visually but to test this unit (as wholel) by ppressure and to locate leaks.
cheers/Igor
rob v
hello
Cheers/Igor
pics below
cheers/Igor
besides -- as per my experience -- this unit gives a head ache all thhe time and the owner can not forget the problem with air in fuel injeection line unless to change this lid assembly. besides sometimes the air is sucted thru hoses bands (!) -- this must alsoo be considered.
cheers/Igor
rob v
hello
Cheers/Igor
pics below
cheers/Igor
cheers/Igor
i went out shopping when i returned to my avensis it would not start (first time in four years any trouble) had to be towed to toyota dealer in derby.
i have just collected my car , repair cost 600 pounds ,,informed that the problem was a soliniod in the starter motor, cant anything be repaired these day do the dealers simply take the easy option to replace only new parts ..customer service my *****
  • 2 months later...
eventually sorted,
new dual mass flywheel and starter as suggested above.
thks igor for your input,was a great hlp
rob v
repairs seem to have caused another issue tho........
