Rev Counter
andy3i
ok iv got a wierd problem
the last few days iv noticed that no matter how hard or soft i drive my st185 the rev counter wont go above 2k
its running ok an doesnt seem to hold back or anything
iv cleared the ecu with thanks to gt4 booster an took it out an the same thing is happening but no error codes an its puzzling me
has anyone else had this problem an if so how did you fix it ?
cheers in advance
andy
the rev counter wont go above 2k or it won't rev above it? just to be clear.
sounds like a dodgy sensor
the needle wont go above 2k, an you know yourself from the tone of the engine that its doing about 6k lol
even if your not driving just sat on tickover then rev it hard it dont rise over 2k
which sensor do you think it might be? i thought crank sensor but it dont throw any codes so its doing my head in
try unplugging the crank sensor and turning it over to see if it is it, some of the sensors that are on their way out don't completely die so don't throw up a code even when their not working as they should
i`ll give that a try tomoro an if it is that then maybe that will help the hestitation i seem to of got just the last couple of days,
