How Do I Connect It Again?
supafly
come through the firewall.. there will be grommits there anough to fit your cable nicely
nah you havnt got the same gromit in there buddy :( if you had the 'nipple' things are either side of the load of wires going either side.
either try and find another way in - or - put a small slit on the side of the gromit and push the wire through there then seal it up with a bit of tape! just dont cut the wires
