Gen7 Ecu Unit Blown?
J888
Hi evereyone...i need some serious help! :S
I recently got a 2005 gen7 and the ABS light came on causing it to fail MOT.
I took it to the local Toyota dealer who said there is probably a problem with the sensors which will cost around £200 to repair.
Fair enough. I just got a call from them saying that the ECU unit has blown, and its gona cost me more than £1000 to fix!!!!
Can anyone tell me if this is a common problem...or are Toyota trying to get money from me?
And if this is the problem....can it be repaired cheaper elsewhere??
I hope someone can help!
Thanks!
Thanks!
ECU's don't just blow. I hope the garage didn't damage it. search bba reman on the web, they can probably fix the ecu for less than a new one.
thanks for the reply..i'll check that out.
Well..they said that the ABS pump has blown and the ABS ECU unit needs replacing.
