Dash
bar
hi guys
what does the signal of a car with lines behind it mean when its lit up on the dash on the st 202 94/99?
it means a rear bulb has blown , or a poor earth on 1 of the bulbs.
nice 1 booster.started panicking when that came on.am i right in thinking to change rear bulbs u have to undo the bolts on the pins and remove the whole cluster?
3 or 4 x 8 or 10 mm nuts , long reach socket is best .
right changed my bulb and has bben fine since sat.seems to have blown the same bulb again today whch is the rear stop.
guessing something is shorting somewhere.
