Power Cap Location
vmail
can the power cap be placed any where
ie across sub
across amp
across Battery after the fuse for the amp
what do the the digital numbers on the power cap measure
i want to put the power cap somewhere where i can see the numbers
its a 18V 1.5F power cap, what is the max power it can take
say if i've got a 600W RMS 1200W peek sub, what would be the best amp to use
what sub is it
the power cap has its +ve terminal in a series connection with the power feed and the -ve is earthed to the body
the display normally shows the running voltage of the cap and usually its charge state
:thumbsup:
those sub values are made up, I gonna get a new sub and amp, should the amp match the peek or RMS
what is the limit if the power cap is 1.5F, are there any cheap makes that I should avoid?
its more important to match the rms values
what do you mean by the limit
and you cant really buy a cheap make one as they all do the same job its just the name that makes them more expensive in some cases
have a look on Maplin Electronics they do some decent ones and they are normally on offer
they are usually a ton a piece but they were on offer with 50% off when i bought mine!
:thumbsup:
bro is getting me 1 off eBay
I think 1.5F is 1500W RMS MAX
dont really trust maplins, 2 of my hard drive coolers have fried
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
