Carina E Estat 2.0 L Automatic
samsara
As I new member to this forum would like to say hello to all members.
now about problem:
I owne a Toyota Carina E estat 2.0L automatic transmision. 1995( N reg) a week ago wile I was driving along a dualcarigway it decide to turn off and since it did not run again.
check point Idone:
1- plugs have sparg
2- fule is present as I check the pluge they are wet with petrol.
3- change ignition coil just incase the spargs are not strong enough
4- service all injectors for if they are sticky or not working properly
my gess is if the ignition timing is not correct but it is not due to distribution position. I wonder if any on ehave same expireance and can help me?
do you know the location of the pikup sensore or know how the ignition pulse working ( if you have workshope manual for this vehicle it may mention it in Ignition System section).
I will appreciate if any body can help me with this problem.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
