Avensis Sr 2001 Front And Rear Washers
moonboots11
Hi
I have an Avensis SR 2001 suddenly I have lost power to the front and rear windscreen washers, although both wipers working OK
Has anybody else had the same problem or can anybody give me any advice on how to fix it
Not sure if its a fuse or wiring problem, seems unlikley that both motors would fail at the same time
Hi
hello mate
firstly you must be sure both botors work fine.
ask some one to listen to the both while you switch them ON.
may be both pumps suction is blocked being a simple issue.
cheers/Igor
I know this is like asking if you have fuel in your tank but do you have water in the reservoir?
Hi
Car taken to a local garage today who confirmed no power to either motor!
Does anybody know if both motors are on the same fuse? It looks to me as though
the fuse is for the motors and the wipers , both wipers are working ok.
Hi
hi
open the bonnet ans have a look on several fuse boxes. open each box covers where you'll fine fuses short description.
it is the speedest way.
cheers/Igor
