I have been Quoted £1000 for new injectors fault code p2002
is this right and if so do i need all 4 injectors confused
Corolla verso T180 06
very confused
Have a look at this T180 issue
yes the dealer tested it and told me it was the injectors
has the dealer got it wrong or do they not know about the Toyota know fault p2002
confused
Your in a tangle here, the other thread mention the Cat being the problem, you could change the injectors and still have the issue. Am not sure what you can do.
  • 4 weeks later...
fortunately mine was under warrente: but toyota lookers in chelmsford essex, charge the best part of £2000 for my new injectors last year. They were sent away for testing at a factory first. My Verso is 2.0 T-D2, 54 plate, which had done about 70-75k miles at the time.
