Oil Consumption
davegooner7
i have 2004 avensis 1.8 vvti with 52500 miles on the clock. i did a service on it 2 months ago i used Castrol magnetec 5w 30 oil. since then it has being burning oil about 1 litre per 600 miles i have being toping up with 0w 40 oil after about 3 top ups i rang my local toyota dealer who told me to come in so they could run a consumption test since they toped me up just under 1 litre, i have done 500 miles and the car has only burned a small amount. my question is would the garage have used a thicker oil or is it something to do with there own brand of oil that stops the problem has any one else experienced this or am i just going mad, i know they are knowing for burning oil but the man in toyota said most of the problems was sorted out by the 2004 engine
thanking you
dave
i have 2004 avensis 1.8 vvti with 52500 miles on the clock. i did a service on it 2 months ago i used castrol magnetec 5w 30 oil. since then it has being burning oil about 1 litre per 600 miles i have being toping up with 0w 40 oil after about 3 top ups i rang my local toyota dealer who told me to come in so they could run a consumption test since they toped me up just under 1 litre, i have done 500 miles and the car has only burned a small amount. my question is would the garage have used a thicker oil or is it something to do with there own brand of oil that stops the problem has any one else experienced this or am i just going mad, i know they are knowing for burning oil but the man in toyota said most of the problems was sorted out by the 2004 engine
thanking you
dave
hello DAVE
firstly - you must be sure what oil viscosity was added by Toyota.
Have you seen the can with the name plate? May be they have simply added the oil with more viscosity?
Cheers/Igor
thanking you
dave
hello DAVE
Cheers/Igor
no when they toped up they used a clear jug which i presume they filled from a barrel which i did not see, my concern is they are using a thicker viscosity oil so it hides the problem
thanking you
dave
hello DAVE
Cheers/Igor
yes, they have added firmer oil to the temperature of the piston.
as the result - the oil consumption become less.
cheers
thanking you
dave
hello DAVE
Cheers/Igor
cheers
is this safe for engine will it shorten lifespan of engine
by the way thanks for quick reply
thanking you
dave
hello DAVE
Cheers/Igor
cheers
i deem it is safe in case this new oil is compatible to 5w30.
cheers/Igor
thanking you
dave
is there any one who works for toyota say what oil they use
thanks
thanking you
dave
Hi mate There is a really good web site called carbible.com there is a good section on all differant types of oil and lubes its really informative it's got info on just about everything give it a go.
thanking you
dave
thanks
http://uk.answers.yahoo.com/question/index...16150622AA4oWnm
just found this site this might help others
dave
thanking you
dave
thanks
dave
Can't see why the dealers would put anything in that wasn't right for the vehicle, it's no skin off their nose to fit a new short motor if one is required, they get paid from Toyota to do it so they are not going to be out of pocket. Had mine done some time back, not a penny to pay.
thanking you
dave
hello DAVE
Cheers/Igor
cheers
cheers/Igor
I deemed they have just drained 5w30 and poured in 10w40 instead.
cheers
when they toped up it was only 1 litre,they did not change all the oil
cheers dave
