Oil/engine Problem So Am Selling The Vvti (gutted)
fiz-vvti
Thats right, damn oil problem, got reckless, didnt check the car/fluid levels and wack....knock knock knock
Have thought about repairing but think it would be less hassle for me personally to just flog it
so i've advertised it
am gutted though, such a beautiful car
how much you want for the car? where is it advertised? thanks.
As a non subscribing member fiz-vvti is not allowed to advertise his car for sale on the TOC forums........Sorry :)
peeps quick question
if the kocking sound is coming from the top half of the engine, what parts am i likely to need in case i decide to repair it
cheers
fiz
cheers
fiz
hi mate
The knocking will be coming from the bottom and will be big end bearings.You will need new set of bearings and you need to get the crank checked out,so maybe a new crank unless it can be repaired,but if you are stripping the engine you should also replace the pistons and rings plus gaskets and oil seals all round.
hope this helps
fazzer my friend,. thank you very much, had it looked ta by the mechanic today, confirmed, its the big end. found out i can get a full engine for £475 and the mechanic will chage £200-£300 to fit it.
But it may be cheaper to get the parts rather than the whole engine....will have to see how it gets along on eBay 1st.
