Do I Need A Fascia To New Headunit On A Cdx Model
CUTEUKM786
HEY,
WILL I NEED TO BUY A FASCIA PLATE IF I WANNA INSTALL A NEW HEADUNIT CD PLAYER ON MY CDX YARIS. I HAVE BOTH THE CD PLAYER AND CASSETTE PLAYER UNIT. WILL THE NEW HEADUNIT FIT IN WHERE THE CASSETE PLAYER UNIT IS?
THANX
Your options are:
1) Use the current fascia that is there now. Remove the cd player that is under the tape player and use that pocket to fit the aftermarket headunit. The standard tape player and cd player are disabled anyway when you fit an aftermarket headunit. As here: http://toyotaownersclub.com/forums/index.p...=20&t=21168
In the above guide it is a factory cd player with a pocket underneath. From what you said I take it you have the factory tape player and the optional toyota cd player where the pocket would be.
2) Use an aftermarket fascia. http://motors.shop.ebay.co.uk/items/_W0QQ_...;_osacat=108815
3) Use the Toyota replacement fascia and rav4 adapter. As here: http://toyotaownersclub.com/forums/index.php?showtopic=28967
BTW please dont use all CAPS on posts. it is taken as shouting.
yeah i have the cd player and underneath is the cassette player (where the empty pocket is in the links)
so what im saying is will a new cd player headunit fit in the space where the cassette player goes?
thanx
Your options are:
Your options are:
will this stop the built in sat nav aswell if i put a new head unit instead of the built in cd player
