anyone had any problmes with the engine stuttering when you accelerate? what can be the problem? :S
At what revs? It should be if you start changing gears over 2500 rpm.
I have noticed the engine sometimes stutters just a little when the AC is on. If it stutters without the AC on then your spark plugs may need replacing.
The stuttering could be many things...some expensive some not. Could be something as simple as a blocked/clogged filter somewhere (air intake perhaps?) or something like the CAT or something. But you should get it checked.
