Fidanza Flwheel
MR2 09
Can any one gove me a review on the fidanza flywheel as I'm fitting one and want to know peoples experiences in gains etc. ;)
Since every one here obviously doesn't like replying to threads i'll let you know my experences.
Exedy clutch and Fidanza flywheeel fitted, the guys down at toyota who fitted the flywheel could not believe the difference in weight between the stock and the fidanza 1. Power gains are amazing, instant power constantly through the revs and perfectly matched with the exedy clutch for the perfect grip.
If any one is thinking of fitting a flywheel deffinatly get a fidanza one, half the weight of a stock one, and noticable gains straight away.
We are not ignorant here honest but as you are obviously the first one on here to have the flywheel fitted that might have something to do with the lack of response to your question :rolleyes:
Thank you for your input and positive report on your experience :thumbsup: all input for Roadster owners helps and I hope there are plenty of other things here that you will find beneficial ;)
Les
Les
Well i hope that my experiences help others out in some way, if any one is thinking of changing their clutch, fork out a bit more and get the flywheel done at the same time. Its a massive improvement and very noticeable. Also if anyone does live in the south east area (croydon) I can recomend a very good mechanic mate of mine who works for toyota and will deffinatly sort your car out nicely.
