Clutch Judder
boilerman
Hi
I need help again, my 2 litre diesel 03, Judders quite violently on lift off on hills, all is ok when moving. I have had the duel mass flywheel/clutch and plate changed twice now paid for first time then replaced again a couple of months later under guarantee. The garage is now saying that the problem I have now 'might' be wear on the gearbox shaft !!
They are prepared to look at the clutch, but are 'putting me off' by saying that if on inspection there is another problem, I will have to pay for the gearbox.
I beleive they are trying to put me off bringing the car back, and if i do take it in, I just know they will ring me and say its a gearbox problem. I have lost all trust with the garage. what do i do ?
Why did you have it replaced the 2nd time after a couple of months?it sounds to me like the clutch again,can you feel pulsation on the clutch pedal when slightly depressed?I fitted a solid flywheel to mine and the car drives better than when we first had it
Hi
Did they check the engine and gearbox mounts when they changed the clutch? broken / damaged mounts can cause clutch judder.
Frank
