Alloy Wheel Requirements - 185 Gt4
mistyangel
i plan to upgrade my alloys shortly and have a few questions,
will non turbo 185 alloys fit the turbo version ?
will mr2 turbo/non turbo/ carina/avensis alloys fit a gt4 ?
the brakes are factory standard, any advice on this appreciated.
Hi, i have the same problem !!!
I was told that the pcd is 5x100 so i found a set of wheels with that fitment only to realize the back wheels were tucked too far under the rear arches.
I was going to get spacers, then someone said not to something to do with rolling resistance or something.
Apparently the best size for the wheels are 15x7 with 205/50's or 17x8 with 215/40's
But i dont have a clue either, keep wanting to get new wheels but seems harder than i thoght !!
I have been in touch with many alloy suppliers in ireland and uk and i am told they dont make alloys for the 185 gt4 anymore
i suspect wheels off an early turbo mr2 would fit, so far nobody on here can confirm this.
will research a little more....!
Hi, done a bit of research and found out this.
The pcd is 5x100 offset between 35 - 38 and bore of 54.0
The only cars i know that have the exact same fitments are,
Celica from 90-current ( gen 5,6 and 7 should all fit )
Avensis
Camry 90 only
Carina
I should think to look for st205 wheels and keep in mind the offset and it should be fine.
Or look for gen 7 wheels and make sure the offset is ok.
Iv got gen 7's on mine and its fine tho they dnt suit the rear as its widebody, could get spacers but would rather get wheels to fit perfect.
You could also use for example impreza wheels with spigots.
Hope this helps,
audi a3 96-03 fit too they are what i have on mine, 16s
pcd 5x100 offset 35 to 45 centre bore54.1
http://www.alloyguide.com/
this is the site i used to find out all the wheels that fit other cars just scroll down to the bottom an you can selct all the manufacturers an see which wheels will fit there are actually quite alot that will fit from different manufacturesr so you should find some nice 1s
ok try these
audi a2 00-
audi a3 96-03
audi s3 00-
audi tt 99-
lexus es250 90-91
mg rover zt 01-
seat ibiza 02-
seat leon cupra r 03-
seat toledo2/leon 99-
skoda fabia 00-
skoda octavia 97-
toyota avensis 96-03
carina t19 90-99
camry 83-91
new shape beetle
golf mk3/4 an vr6
new jettas an v6
