i need to know if 3s gte engine can be mount on a toyota paseo 1992
if i have to change transmision , mounts ect
need your help i will be glad if you guys help me
tahnks
yes it will fit but you will need an MR2 turbo transmission, drive shafts, engine wiring loom and ecu.
engine mounts will most likely need to be custom fabricated as will an exhaust system.
there is quite a lot of work involved in the conversion and other things like suspension and brakes will need uprating.
good luck and keep us posted
thank me friend i raly apreciate you help
