Questions About The 3sgte?
I just recently purchased a Sw-20 and did a compression test. Can anybody here tell me what the stock compression with a guage is on a american 3sgte with a ct 26. eg 150, 160. Thanks.
common now just because i own a a-71 you can give me some info... its a 91 na with a 3sgte in it. I want to know if it possibly has a higher spec mota in it. its at 180 all the way down.
3S-GE 12.5kg/cm2 (178 psi or more)
3S-GTE 11.5kg/cm2 (164 psi or more)
5S-FE 12.5 kg/cm2 (178psi or more)
:thumbsup:
