Dear all,
I note that sometimes when i'm in traffic & leave my foot on the brake, sometimes i feel the pedal moving a bit forward..... what do u think it is? Is it normal? My brakes still work gr8, ABS works prefectly too.
Rgds
Does it only happen when you have the air-con on? If so then I would say it's normal as I've noticed the same on my Yaris - I think it's when the air con compressor clicks on.
By the way, it's not a good a idea to keep your foot on the brake as if the disc is red hot then it can warp. Use the handbrake instead :thumbsup:
I think only when i have the aircon on mate.....10x for the advice!!
Any more views dear friends?
If you pump the brake pedal with the engine off, then turn on the engine, you'll feel the same thing- brake pedal lowers. It seems normal
Yea, totally normal if its just going down a bit
