No Air From Heater/aircon
0lordy
Hi there,
I've a problem with my 04 Avensis T3X: the heater/aircon does not blow out any air from any of the vents. If I have the aircon on full, I can feel some cold air at the vent, but it's not coming out at any speed. Likewise when the heating is on.
It would appear that it's blocked, but I would think it unusual for the internal ducting to be so completely blocked.
Has anyone seen this type of thing before?
Hi there,
I take it you've checked the filter under / behind the passenger glove box ? They can really stop the airflow if they are blocked.
Hi there,
hello
change the salon filter and try again.
cheers/Igor
Hi there,
Hi mate we have the same car 04 t3x when you change the filter you will note a marked improvement
there about 20 quid the filters get a bit grubby .
Brilliant guys, did the fix - only brushed and vacuumed the filter, and it's working reasonably OK - will replace it & I'm fully sorted.
Thanks a million for your help.
