Glass Marks And Scratches
david j starkie
:help: Is it possible to buff out marks on the door windows?
and if so what is the product called, i was told you can but hav'nt seen
anything in the shops is it only for the trade? if anyone has used it and
got good results id like hear,thanks :thumbsup:
Have a looky here and hopefully this is what you require :)
Good luck :thumbsup:
Can only echo Pheonix999 on this one, you will need a lot of patience as well. If the marks are deep you may be on a losing battle. Jewellers rouge is a very fine abrasive powder for polishing out marks and works in the same way as T-cut for paintwork removing the top surface of whatever you are polishing, so whatever the depth of the mark, that is the depth of glass you have to polish away to remove the mark.
Don't know of anything else that is tough enough to touch glass.
nice one mate i think ill try it out at weekend ill let you know , if you see a post on here about where to get cheap windows from
you'll know whats happened :D
