Retrofitting On An 04 Plate
sgts
I've found myself a b9010 out of 56plate avensis is there any way of installing this in my 04 avensis which has the normal satnav? if so what equipment is required? can i use the normal sat nav drive and antenna? thankss
I did this on my 05 T Spirit. You will need a new front facia from Toyota at around £39 if you don't have one with the 9010. I fitted another GPS aerial on mine as I kept the TNS310 in place so I can remove the 9010 when I sell up. You also need to pick up the speed signal from the back of the TNS under the passenger seat (or elsewhere) and run it it the 9010. I didn't bother with the reverse signal as I don't have a back up camera fitted.
I didn't have the speed signal plug for the 9010 and Toyota can't supply any more but I found an easy alternative plug and wire for the speed signal input.
If you get serious about doing this I can let you have more details - once you have the facia and the speed signal it's not too bad a job. Once I fitted the GPS aerial and the speed signal lead fitting the 9010 was a easy job.
Steve
  • 6 months later...
Hi Steve,
I'm swapping out a TNS310 for a TNS700 at the moment, have the GPS Antenna fitting, when to take out the TNS300 and the connectors are different to the TNS700, is there some wire harness I need? This is in a LC120 Landcruiser. Thanks for your help
Paul
