My 1995 2 litre gti Carina E just failed the MOT on no main beam. Strange thing is that you CAN get main beam by holding the stalk towards you (flash mode) but when clicking it forward into main beam, blue main beam light comes on on the dash but main beam does not work.
Side lights & dipped beam are OK & fuses appear OK under bonnet & drivers side (might check if more fuses passenger side).
Any ideas guys?
Sounds like it's something inside the actual stalk, maybe its one of the lobes inside thats worn. Might be worth getting hold of a second hand one and try that see what happens.
I am sure you are right, as I spent many hours 'fiddling' & found out that the main beam switch switches the bulb to ground & this was not happening, although I could make it work by grounding the main beam wire at the headlight.
So, not having a manual & not wishing to set the air bag off, all I did was to fit a toggle switch just to the right of the ignition lock, one wire to earth, the other to the main beam wire.
Works fine & MOT tester was well happy with it!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
