Beeping When Locking My Car Using The Remote Keyfob?
Ed_Tsport
my car has started beeping when i go to lock it with the remote keyfob, what does this mean? is it just a low Battery indicator? thanks
What version of Yaris do you have? Is it beeping from the car? It’s either your door/boot/bonnet isn’t shut properly. Look through the window when you are outside of the car and look at the dash board to see if the ‘Open door’ light is illuminated.
yeh problems solved, iv got two little pieces of carpet on the boot sill so i dont scratch the paint if i lift anything heavy into the bot. turned out one of them got caught in the boot allowing it to latch but not close fully, enough to make the car think it was open :) thanks
