Overheating 7th Gen Celica Gts
onebadcelica usa
hello every one! i wanted to see if there was anyone out there that has had the same problem i'm having and if so can u help me fix it!
i have a 2000 celica gts 1.8 vvtl-i ( :D love the car) but out of the blue it started to overheat on me. i changed my thermostat, hoses, radiator, the only thing i haven't changed is the water pump but i dont think its the water pump because it takes the car about 20 to 30 min to start overheating it did this once and i had air in the system and bled it out but 3 mths after it started all over again. can some one please help i'm going crazy over here!! :(
thanks!
you could try replacing the coolent that may fix it sometimes when the coolent is old you get overheating problems. another thing to try is some supercool coolant aditive (millers is good) that mite give you a temp or perm fix!!
:D :P
http://www.demon-tweeks.co.uk/products/Pro...ode=MOL1304-250
http://www.demon-tweeks.co.uk/products/Pro...;pcode=CAS4LIFE
http://www.demon-tweeks.co.uk/products/Pro...;pcode=RED80204
http://www.demon-tweeks.co.uk/products/Pro...pcode=MPCSTOPOH
those are some products that work well!!
:D :P
Thanks lex but i changed all the fluids and the radiator so everything is new so i dont think that is working :( but i think im just going to have to change the water pump :( and see if that's the prob. i will keep you guys posted. if its not im going to be sooo mad! but happy at the same time lol i need to get this over with! lol
:D :P
well here is an update i just changed the radiator and guess what! didnt work!!! its still overheating :angry::angry::angry: I DONT KNOW WHAT THE HELL TO DO!!!!! SOMEONE HELP PLEASE!!!! :(
