Gt-4
mad1969
hi there can anyone tell me the pin out number and colour of wire from the ecu to fit a fuel cut defencer and also what wire from the air flow metre pls
thanks
you might be aswell putting the yr of yours on etc, do you know what make it is,iv just looked at the instructions for mine an they are different for 1989-1992 1992-on, mine is just a cheap 1 of eBay with 3 wires to connect if its the same as yours i can post you the wire colours an connector numbers if that will help
mines made by hks got 4 wires red/black power & neg and then a yellow & white they go to the ecu and air flow metre
you should really need one to be honest unless you've got management which should be able to remove fuel cut anyways. it's just a cheap mod that could lead to an expensive re-build
