Avensis Verso Speed Issue
kaira
Hi there! I
have Avensis verso d4d 2002.I have been driving my car about 1 year,but my car has problem with speed.In 3rd it goes as far as 80kms and then now matter how hard you push the accelerator its doesn't go any faster. It feels as if every gear has some kind of limiter. In 5th it doesnt go faster 130kms. Any ideas?
Regards
Kaira
Hi there! I
Regards
Kaira
sounds like you may have a speed limiter or maybe cruise control have a look at your owners manuel failing that go to a
toyota dealer and ask them to plug in the diagnotic.
Hi there! I
Regards
Kaira
I see. Thanks for the reply.
Hi there! I
Regards
Kaira
hello
each HP fuel injection pump is allowed to adjust a cycle portion of diesel.
i feel the problem is there. WHether you have been repairing fuel injection system before?
May be another simple problem with fine fuel filter clogging strarting that allows a limit of diesel to pass thru resulting this issue.
Cheers/Igor
Hi there! I
Regards
Kaira
hello
Cheers/Igor
BESIDES -- whether your HP pump is controlled by some vacuum attachment?
Hi there! I
Regards
Kaira
hello
Cheers/Igor
Hi Igor! HP pump is electric,and pedal of acceleration has electrical sensor drive by wire.Regard Kaira
Hi there! I
Regards
Kaira
hello
Cheers/Igor
hi
the pump canot be electric but only solenoids are controlled by el. signal. the pump is driven by means of timing gear.
but the problem is still actual. another question -- what is the link between gas pedal and the pump itself? is it some levers or just el link?
cheers/Igor
Hi there! I
Regards
Kaira
hello
Cheers/Igor
hi
cheers/Igor
Hi! I checked up my car in Toyota center and found problem.Problem was with car board computer-mistakes.I give you buzz.Thank you very much.Regards Kaira
Hi there! I
Regards
Kaira
hello
Cheers/Igor
hi
cheers/Igor
OK cured, then
:thumbsup:
