205 Gear Change Problem
Quagmire-st205
hi lads. ive just noticed lately that when im changing gears, its very stiff to get it into gear, mainly first and second taking off. the clutch isnt slipping but when letting it out, the pedal stops up about three quarters way out then just pops out fully.. anyone else with a 205 have had any similar problems??.....
any help would be great... thanks
hydraulics ?
hydraulics ?
like a slave cylinder??? i looked around the pedal and the nut on the adjustable rod was loose, just nibbed it up but no difference..
did you have any similar problems??
have mine bout two months, what common faults are on these or what could i be looking out for?...
thanks mate
hydraulics ?
thanks mate
sound like clutch plate is a bit tight maybee does it "clunk" into reverse?
check clutch fluid levels , check the cylinder on the gearbox is working ok , have someone press pedal while you look . the other thing that wears out are the brass bushes in the selector rods that connect to the gearbox . they get oval shaped and become lumpy and awkward at the gearstick , i swapped mine out for the roller bearing kit on eBay , difference was awesome.
oh and the clutch pedal may need bleeding , do it the same as you do brake calipers.
check clutch fluid levels , check the cylinder on the gearbox is working ok , have someone press pedal while you look . the other thing that wears out are the brass bushes in the selector rods that connect to the gearbox . they get oval shaped and become lumpy and awkward at the gearstick , i swapped mine out for the roller bearing kit on ebay , difference was awesome.
not seen this kit on eBay any chance of a link
thanks
