Oil Leak
bouldy_
Hiya
I've just discoverd my st202 has an oil leak, i wondered if this was a common problem and would it be much to fix? It's coming from (looking from the front) the left side of the engine.
Mike
start from the highest point you can trace the oil to . may well just be the rocker cover gasket . its possible to just nip each nut down in a diagonal order and the leak could stop , but it all depends where its leaking from .
