Gen 6 Not Starting
nathy_t
Hi there,
any help with this problem would be very much appreciated.
My celica sr just won't start! the strangest part is about 3 hour prior the car was working perfectly!
I put my key in and first and second click work fine (all dash lights come on, radio and clock working) the when i go to the 3rd click to turn the engine over the whole car cuts out and disconnects from all electrics, then had to wait for it to come back and same problem again. so thought maybe Battery had died so went for jump start which brought the electrics back but once again when i go to start the engine just totally cuts out. when it cuts out everything goes, ive tried all 3 keys i have and the same problem for all 3! im totally lost. ive currently disconnected the Battery hoping it might reset the immobilising system.
any help would be great thanks,
nathan
sounds like a short on the starter circuitry.
try taking the live off the starter ( be carefull not to let it earth out anywhere ,) now turn on the ign and see if the lights go out on the 3rd click .
