Celica Pollen/cabin Filter
donnyvfr
after changeing my pollen filter on my avensis my mate want to know if his 52 plate celica has a pollen filter also, if so where is it and how do you change it, cheers
On the Gen 7, the Pollen Filter is located behind the Glove Box. Although I haven't changed one myself, I've heard it's quite straightforward.
dead easy just behind the glovebox. i fink its just a few clips and a screw just be careful when changing it not to loose andy screws and not to get dust/pollen evryware!
Yep, can be done with no tools as far as I can remember!
Pull open glovebox, and either side of it there are two black clips that turn and remove allowing it to open wide. Behind is the pollen filter housing, which simply pulls out with a click.
