Engine Failure Signal
mela
Hi
I have yaris D4d with 5000 Km, and today when I turned the key, the engine didn't want to work. And appeared the signal yellow - engine failure. I'm so worried
Has any work been done under the bonnet recently e.g. pressure wash/ steam clean? If so water may have got into the sensors or sensor plug(s) diconnected. If no work has been carried out then call the main Toyota dealer to repair under warranty.
No work has been done. The car works but the signal keeps standing. Tomorrow if the warning signal is still on I 'll go the toyota garage. anyway, after I had water leaking problems with my aygo and after rejected that car, I stll trust toyota . Maybe I'm not lucky with cars.
