One More Thing For Jimlad To Spend His Dolla On!
That thing sounds like Darth Vader's Tie Fighter.
:D
Fensport sell a manifold which uses an external wastegate...
Its £1200 so not cheap, you will also need a bigger turbo and the wastegate.... but it does sound good...
Matt.
Wastegates basically perform the same role as BOVs - to relieve boost pressure from turbos, thus stopping them from going bang.
In order to fit an external wastegate - you'll need to weld a wastegate flange onto the exhaust manifold before the air reaches the turbo, and weld up the actuator flapper in the turbo, and ditch the actuator.
Hope that helps..
Ben
ah... so it is possible then... Mmmmm.
Hope that helps..
Ben
Im not sure if its possible, but he put enough big words in to make me believe anything he ever says about turbos! lol :lol:
