Disaster!
ajcluck
Hi all,
I was driving along quite the thing last night when all of a sudden i was hearing and feeling something strange coming near side front wheel, straight away i feared that it was the superstruts, however on investigation it was my alloy just away to fall off! i have sheered the bolts that hold the alloy on! can you bore these bad boys out or is it a new hub?
p.s. just had new tyres fitted and the guys doing it must have forgottn to nip the nut up!
you can buy new studs and they just press into the drive flange. best way is knock the old ones out (after removing disc and calliper) pass the new stud through the hole then using a wheel nut and a spacer pull the new one through.
id get intouch with the company that fitted the tyres as they are responsable and should put it right.
i feared the worst when i read the title, glad its just a wheel, sort of.
so it is not as bad as once feared! where will i be able to get these?
haha sorry about that
I would be going back to them for it sorting!!
Trading Standards is a good threat to use ;)
Unfortunatley they have a disclaimer stating you should check them after 50miles
I would still speak to Trading Standards.... in some cases disclaimers are worthless ;)
toyota or eBay. infact you can get them on eBay that are longer than stock if you ever thought about using spacers. other than that MR T or a breakers. IIRC all toyotas have the same studs. they just knock out so no problem.
thank god it was just your wheel, when i read the title i thought it was going to be your engine!
how's the run in going except from this set back?
hi all, needing some more help, i am currently in canada and i need a part number for replacement studs so i can get my bro to order them from toyota and they will be there for me when i get back.
cheers
