Hello,
Can anyone tell me the alternator output for an EP91's(4EFE) alternator??
I've got a Stinger SP800 Battery and have had some problems with it today!!
Had to bump start my car to get it going earlier!! Took it for a nice long ride to my local Shell to fill it with Optimax cos I thought it would charge it up. But when I got back in my car after filling it up, it would not start. I the had to wait 30 mins for the boss to come with her brother to bump me off again. Not good!!!!
Now after reading my info on my Battery, after having it nearly a year. The table of charge info says:
Automotive current tapering charger rated @
10 Amps min 20 hours charge
15 Amps min 16 hours charge
20 Amps min 12 hours charge
30 Amps min 5 hours charge
40 Amps min 5 hours charge
50 Amps min 3 hours charge
100 Amps min 30 mins charge
This is why I need to know the output.
Nath
I don't have access to that info, but I can tell you a few simple tests to perform if you have a voltmeter. Start with a voltage reading first thing in morning. Start engine and get voltage while cranking and once running. With engine running turn on every accessory the car has and watch voltage as you go.
A healthy system will have these minimums.
12.2 first test -lower most likely Battery
11.0 second - lower battery/starter
14.0 third - lower alternator/battery
13.0 fourth - lower alternator
Of course these tests are assuming the terminals are clean and tight. As are all ground connections.
Found out myself.
The answer was looking for was 12V @ 55A
My alternator hasn't been charging my Stinger Battery properly and has f :censor: :censor: ked it up.
So I have bought a new monster size Toyota Battery for £45 it 48Ah
:thumbsup:
