1999 Avensis 1.8 Petrol
john45
Hi I am trying to replace front brake pads, the bolts holding caliper on are inside a rubber sleeve, looks like it needs allen key to undo it. Any one any idea what size I need to get. Also where is the best place to buy pads and discs from.
Thanks John
7mm if memory serves me correct - you can buy a special long key for this exact task, with an equally long rubber covered handle to a few pounds from most good parts shops.
